  ignition control module? HELP
ignition control module? HELP by heavyRfoot
Started on: 11-29-2013 06:24 PM
Replies: 7 (363 views)
Last post by: heavyRfoot on 12-01-2013 06:50 PM
heavyRfoot
Report this Post11-29-2013 06:24 PM Click Here to See the Profile for heavyRfootSend a Private Message to heavyRfootEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok so was driving her around today and all of a sudden she started to spit and sputter and shut down. well I was low on gas so I filled it up and still the same thing well got it back to somewhat of a safe area shut it down for about 30 min. went out to restart it it cranked over and started for about a sec. after that all it did was crank and crank nothing haven't check to see if it has spark yet but I know its getting gas since I hit the valve and it sprayed me. also when it was spitting the rpms would jump up and down. so does this sound like the control module
maybenot
Report this Post11-29-2013 06:52 PM Click Here to See the Profile for maybenotSend a Private Message to maybenotEdit/Delete MessageReply w/QuoteDirect Link to This Post
gotta post this in technical forum, sorry i cant help
heavyRfoot
Report this Post11-29-2013 07:49 PM Click Here to See the Profile for heavyRfootSend a Private Message to heavyRfootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry about wrong section been a while since I posted on here and was in a hurry. So it isn't getting spark I did just check that a little bit ago
mrfiero
Total ratings: 150
Report this Post11-29-2013 08:07 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
No spark could be the coil, ignition control module or the pick-up coil.
The pessimist in me says remove the distributor cap and watch the rotor as someone cranks the engine over. If the rotor doesn't spin then your timing chain broke, This is unlikely to be the problem, but it happened to me once many years ago and it took a long time to figure it out.
Fiero Thomas
Total ratings: 124
Report this Post11-29-2013 09:06 PM Click Here to See the Profile for Fiero ThomasSend a Private Message to Fiero ThomasEdit/Delete MessageReply w/QuoteDirect Link to This Post
When you crank the motor if the tach does not bounce then its the ICM.
1986 Fiero GT 1984 Corvette
1992 Bonneville SSEI 2009 Dodge Challenger SRT8
FieroNews
1MohrFiero
Total ratings: 157
Report this Post11-30-2013 09:47 AM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
It sounds very much like the ICM, I went through almost the same scenario when I first got my car. If that doesn't fix it check the coil next. Many times the two go out together.
maybenot
Report this Post11-30-2013 05:48 PM Click Here to See the Profile for maybenotSend a Private Message to maybenotEdit/Delete MessageReply w/QuoteDirect Link to This Post
i just reread my comment. to be clear, i didnt mean i wont help because you posted here, i was trying to steer you to get more replys.
heavyRfoot
Report this Post12-01-2013 06:50 PM Click Here to See the Profile for heavyRfootSend a Private Message to heavyRfootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok its now going again it was the icm. Plus the distubutor was loose so had to retime it by ear. But now my tach filter is fried my tach is waving at me all the time but its home and safe. Thanks for all your help
