  Pirahna Dash?
Pirahna Dash? by fierogtlt1
Started on: 11-13-2013 11:29 PM
Replies: 12 (1310 views)
Last post by: dobey on 11-16-2013 01:42 PM
fierogtlt1
Report this Post11-13-2013 11:29 PM Click Here to See the Profile for fierogtlt1Send a Private Message to fierogtlt1Edit/Delete MessageReply w/QuoteDirect Link to This Post
What car is the dash from that is in the Pirahna car? Or is it a custom dash?
Khw
Total ratings: 134
Report this Post11-13-2013 11:52 PM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's part of the kit (if i remember correctly), which isn't made anymore.
yellowstone
Total ratings: 250
Report this Post11-14-2013 08:45 AM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
But you can now get this (upholstered any way you like...)
PM Amida for more info.
TXOPIE
Report this Post11-14-2013 10:03 AM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
These are the best dashes...already own one of them and going to order 2 more in the next 12 months!
bmac
Report this Post11-14-2013 11:29 AM Click Here to See the Profile for bmacSend a Private Message to bmacEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those dashes are really awesome! Would you guys mind disclosing the price? I'm really interested in doing a dashswap.
Brian
hnthomps
Total ratings: 50
Report this Post11-14-2013 11:52 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like this one as well as the posted ones. It is from the same supplier so the quality is quite nice.
Nelson
TXOPIE
Report this Post11-14-2013 11:54 AM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
G1 Dash:
Glove box is from Pontiac G6 and for pricing:
G1 Dash parts kit.................... $1599.00
New Solstice vents....... $225.00
Trim/prep/upholster........$1200.00
Extras......per quote
Below is the parts/price info on the standard Fi355 interior set, modifications may be additional.
FIERO INTERIOR CONVERSION DETAILED ITEMS LISTING
This is a finished interior set ready for upholstery. All parts are trimmed, prepped & pre-fitted for a
stock/un-modified Fiero cabin. Final fitting in your car should be performed before upholstery if your
interior cabin is modified. All panels attach to stock Fiero mounting points.
Other items needed are:
1) VDO guages 3 3/8" & 2 1/16" & VDO senders.
2) OEM Ferrari air vents (must check with dealership for latest price/availability)
Or, try Ebay for a used set.
3) Euro shifter arm from Rodney Dickman.
4) Optional HVAC controller from 'Riceburner98', about $350.
5) Your own wiring.
6) Plug/connector for power mirror switch from mid 90's to late model GM
b-body, truck/suv (GM part# 12101762) I can supply for $75usd.
7) Upholstery. Optional upholstery available before shipping.
You will also be re-using your original dash & console screws, and the original upper door
handle brackets and screws. All other needed hardware is included. An installation guide is included.
Included items:
Dash 1 Upper dash body
1 Lower Dash body
2 Defrost vent covers
1 Custom moulded main A/C airbox
2 air vent hoses
1 “Glove box” lid with axle & bushings
1 magnetic touch latch
1 Center gauge/stereo panel
1 headlight/dimmer switch panel
1 Upper steering column shell
1 Lower sterring column shell
Main Instrument pod assembly
1 Main gauge pod shell with brackets
1 Custom gauge panel with graphics- preassembled
1 Flat black acrylic/urethane panel
1 Dark acrylic tinted indicator lens
4 Indicator light sub-panels
12 Light bulbs & sockets
12 color Instrument graphics
Door Panels
2 Main door panels
2 Upper door-pull housings
2 Armrests
2 Lower door pocket panels
4 End caps
2 Felt lined weather strips
2 Double foil fiber insulation
2 Custom powder coated steel release paddles
2 Custom release mechanisms
easily mounts to doorframe
smooth bearing operation
automatic spring return
1/8" steel levers
2 Urethane/steel pistol grips
2 Insert covers for stock Fiero lock sliders
3 Illuminated power window switches w/ bezels
1 wire harness w/ matching terminal sockets
Console 1 Console body
1 Computer cover
1 6 speed aluminum gate
1 Forward deck/switch panel - preassembled
1 Urethane deck panel
1 Illuminated switch cover w/ graphics
2 door lock toggle switches
3 accessory toggle switches
5 Toggle finger caps
4 pushbutton switches w/ graphics
1 Rear deck/switch panel - preassembled
1 Sliding "ashtray" cover
1 Urethane coin cup (in place of ashtray)
1 support underpanel
1 Illuminated power mirror switch
Hardware
Pricing:
(S&H extra)
Full interior set (no upholstery). Fully prepped & pre-assembled with all fabrication completed, pre-trimmed &
pre-fitted: $3995usd (w/o vents) Send your 355 vents to me for pre-fit.
Add $395usd for optional console storage compartment.
Upholstery (optional USA & Canada only)
Full interior upholstery in leatherette (simulated leather) with foam padding and french stitching.
Single color, or two tone: $1795 - $1995usd.
Full interior upholstery in genuine leather single color, or two tone with foam padding & french
stitching: $2295-$2795usd (pricing varies depending on color choice & availability).
Contact Robert.Kusakabe@comcast.net for more info.
[This message has been edited by TXOPIE (edited 11-14-2013).]
lou_dias
Report this Post11-14-2013 12:31 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Piranha dash was a modified 3000GT dash with modified Firebird door panels. The Piranha nose was a modified 93-97 Firebird Formula nose.
Here's the nose in question:
http://www.camaroz28.com/fo...la-cc306-etc-698686/
Modifies the grill area and side marker lights:
The fender lines are identical.
[This message has been edited by lou_dias (edited 11-14-2013).]
Danyel
Total ratings: 169
Report this Post11-14-2013 05:50 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd sure like to know where you got that info?????.
My Build Thread
Tylers Toy
cyrus88
Report this Post11-14-2013 06:50 PM Click Here to See the Profile for cyrus88Send a Private Message to cyrus88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've always loved the fiero dash. It is unlike any other car's. I like that it sort of looks like a small plane cockpit. The dash pics posted from Amida's are very nice, but I wouldn't have a fiero without its dash exactly the way it is already.
RCR
Total ratings: 102
Report this Post11-15-2013 05:59 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Lots of pics of the creator and Plazma here: https://www.fiero.nl/forum/Forum1/HTML/041016.html
Bob
jscott1
Total ratings: 415
Report this Post11-16-2013 12:04 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
These dashes are awesome and appear to be high quality, but the problem is that most Fiero owners are not willing to spend that much. Some are willing obviously, but I wish anyone luck whose business model is selling to Fiero owners.
dobey
Total ratings: 371
Report this Post11-16-2013 01:42 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, they are hand made, and made to order, not stocked. It helps to not have tens of thousands of dollars invested in stock that people won't buy. Making one-off for yourself before you start selling them, to get things right, and pull a mold from, helps keep costs and potential losses down, too.
And I think Rob makes parts for more than just the Fiero community as well. My understanding was he was making similar parts for the kit car community long before he started making them for the closer to stock Fieros.
