  Have Spark, Have Fuel. Cranks but no Start. Help!
Have Spark, Have Fuel. Cranks but no Start. Help! by Str8lineJKing
Started on: 08-08-2013 06:40 PM
Replies: 5 (234 views)
Last post by: Frizlefrak on 08-09-2013 02:37 PM
Str8lineJKing
Report this Post08-08-2013 06:40 PM Click Here to See the Profile for Str8lineJKingSend a Private Message to Str8lineJKingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, So im probably going to catch some flack for posting about this as i am new here and there
are a couple posts with a similar problem but those posts dont really cater to my exact problem.
Heres the rundown!
1984 Fiero SE 2.5 4-Speed
So anyways,, I bought this car two weeks ago and am really stoked to have a fiero and get it running. I however am having some
trouble getting it running. I replaced the headgasket and fuel pump. The engine has been rebuilt with approximately 20k miles on complete fresh rebuild.
I have fuel pressure and the injector is pulsing fuel into the TB. I have used a spark tester on all four cylinders and it showed good. I seem to be
missing something though. (OBVIOUSLY) I just wanted to consult the great and powerful PFF.
Side note. I know the ignition timing is correct as i have gone through the whole procedure of TDC compression on cyl. #1
Thanks in advance! I hope someone can be of some help to me!
Str8lineJKing
Report this Post08-08-2013 06:42 PM Click Here to See the Profile for Str8lineJKingSend a Private Message to Str8lineJKingEdit/Delete MessageReply w/QuoteDirect Link to This Post
So sorry! I am new here and just realized i posted this in the wrong section!!! So sorry!
EvilSqueezles
Report this Post08-08-2013 09:05 PM Click Here to See the Profile for EvilSqueezlesSend a Private Message to EvilSqueezlesEdit/Delete MessageReply w/QuoteDirect Link to This Post
It happens.
Frizlefrak
Total ratings: 72
Report this Post08-08-2013 11:45 PM Click Here to See the Profile for FrizlefrakSend a Private Message to FrizlefrakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Run a compression test and post the results for all 4 lungs. I'm betting your valves are out of adjustment.
[This message has been edited by Frizlefrak (edited 08-08-2013).]
Str8lineJKing
Report this Post08-09-2013 12:31 AM Click Here to See the Profile for Str8lineJKingSend a Private Message to Str8lineJKingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the reply, but i reposted the topic in the Tech and Questions section. Got reminded that since it had sat a while the compression was probably down. So i put oil in each cylinder and she fired right up!
Frizlefrak
Total ratings: 72
Report this Post08-09-2013 02:37 PM Click Here to See the Profile for FrizlefrakSend a Private Message to FrizlefrakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Excellent! Glad to hear it's running.
