  ugh... bad clutch? fed up
ugh... bad clutch? fed up by LoW_KeY
Started on: 07-08-2013 05:41 PM
Replies: 5 (224 views)
Last post by: LoW_KeY on 07-09-2013 09:55 AM
LoW_KeY
Total ratings: 150
Report this Post07-08-2013 05:41 PM Click Here to See the Profile for LoW_KeYSend a Private Message to LoW_KeYEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well car runs good, not sure if anyone else had spec 3 related issues. Been a good 10 years in the car... passing from 55 in 4th felt something, then for the true test tried 3rd at 50... car fell right on its face. When on dyno had no knock... so I'm guessing clutch possibly?
go figure right when I'm out of funds ugh and don't have access to a garage like I used to...
any suggestions on clutch? cars making 300/360 @ wheels... thought stage 3 would've been good? and I haven't really put many miles on it since the motor swap cause of issues here and there and fine tuning.
I'll trade clutch for M90 charger with TB and DUB system
3800 SC/IC Formula whines more than your girl...
08 Cobalt SS TC - ZZP tuned, K&N SRI, 6k HID's 13.31@107
07 HHR - Wifes (tried to have her get the SS)
Report this Post07-08-2013 06:23 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tach climbing but not the speedo when accelerating from 55 in 4th?
LoW_KeY
Total ratings: 150
Report this Post07-08-2013 10:07 PM Click Here to See the Profile for LoW_KeYSend a Private Message to LoW_KeYEdit/Delete MessageReply w/QuoteDirect Link to This Post
Im thinking so... if I use 3rd from 30 goes fine... tried from 50 fail... hit 4th again then seems like it caught.
I'm at a loss.... if I go from stop... drag strip last year was fine, then 2nd time same thing so now throttle fixed thinking clutch is on way out.
I've hard of people having issues with stage 3 spec. Just don't know if 4 would work? Sucks I just want it right for one year
doublec4
Total ratings: 150
Report this Post07-08-2013 10:16 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well you did say it's been in there for 10 years?
Might be time for a new one. I just had a 3+ put in and I love it so far.
California Kid
Total ratings: 274
Report this Post07-08-2013 11:47 PM Click Here to See the Profile for California KidSend a Private Message to California KidEdit/Delete MessageReply w/QuoteDirect Link to This Post
The first sign of a clutch going out is slippage in high gears.
LoW_KeY
Total ratings: 150
Report this Post07-09-2013 09:55 AM Click Here to See the Profile for LoW_KeYSend a Private Message to LoW_KeYEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've always been used to a clutch slipping in first.... grabs in first and second... maybe slipping from heat etc?
