  1988 Sport Lowering Springs
1988 Sport Lowering Springs by California Kid
Started on: 05-06-2013 08:20 PM
Replies: 12 (2286 views)
Last post by: tebailey on 04-28-2014 06:03 PM
California Kid
Total ratings: 274
Report this Post05-06-2013 08:20 PM Click Here to See the Profile for California KidSend a Private Message to California KidEdit/Delete MessageReply w/QuoteDirect Link to This Post
Curious if anyone had tried the Sport Lowering Springs for the 88 GT that are available from "The Fiero Store" ??? If so, how would you rate them compared to stock ?
Also curious if someone has a OEM Stock Frt. and Rr set for a '88 GT in excellent condition sitting around collecting dust, that they might be interested in parting with ?
Car History: https://www.fiero.nl/forum/Forum1/HTML/025670.html
California Kid
Total ratings: 274
Report this Post05-07-2013 11:45 AM Click Here to See the Profile for California KidSend a Private Message to California KidEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump.......still looking for some feedback.
cam-a-lot
Total ratings: 97
Report this Post05-07-2013 09:32 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have them in my car and they feel extremely harsh. I suppose it is possible that the issue is my poly bushings in the rear, or perhaps the springs were not installed properly, but every time I hit even a small pot hole, it feels like the springs don't even exist. I have new Monroe struts and Fierostore 88 springs.
California Kid
Total ratings: 274
Report this Post05-07-2013 09:48 PM Click Here to See the Profile for California KidSend a Private Message to California KidEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you very much for that honest response. No one likes to admit that a change made a negative impact or didn't meet your expectations and I appreciate your post.
FieroDan86
Report this Post05-08-2013 12:31 PM Click Here to See the Profile for FieroDan86Send a Private Message to FieroDan86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have all poly on the back of my '88GT with the stock springs and it doesn't feel harsh at all. Actually I feel the stock springs are too soft for me so will have to try some different springs. I still have the stock springs on the front too and I feel there's too much space showing in the front wheel well so was planning on cutting one coil off next time I have the suspension apart.
Leeloo88
Report this Post04-27-2014 09:50 PM Click Here to See the Profile for Leeloo88Send a Private Message to Leeloo88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I know this is an old post and you've probably moved on by now but I was looking for this info years ago when I first installed my lowering springs and poly all around. 88 Formula. Since I couldn't find anything about it I figured I'd pull the trigger and see how it played out. Hope this stays in the forum and helps somebody else looking to do the same thing.
My set up is the Fierostore 88 1" lowering springs all around, poly bushings all around and the koni adjustable shocks all around. I installed it about 4 years ago. It was SUPER harsh. It was actually so bad that I retired my car for the next four years all the while putting off correcting the problem. Well now I've sold my truck, pulled my 88 out of deep storage and put it back on the road. The springs have settled in, and it looks good as ever. Nice and low. Unfortunately its still SUPER harsh. Felt like Fred Flintstone's car.
That was an accurate description since I've had it up on a shop lift I inspected the suspension to see why it was so hard, even with the koni's at full soft setting its riding like there was no shock. I can see that its the bumpstops! When I installed the springs I didn't check the amount of space between the bumpstops and since nobody told me to remove them or cut them down they got re-installed. I believe this is the problem and I will be removing them to see what kind of improvement I get.
Four Fans of Freedom
"Fiero Fugit"
Total ratings: 463
Report this Post04-27-2014 10:18 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Leeloo88:
...When I installed the springs I didn't check the amount of space between the bumpstops and since nobody told me to remove them or cut them down they got re-installed. I believe this is the problem and I will be removing them to see what kind of improvement I get.
I wouldn't remove them. Just cut them down.
My 88 has 86 GT front springs (noticeably stiffer) cut down by 1.25 coils, in the front, and 88 front springs, cut by one coil, in the rear.
I believe this is supposed to increase the spring rates by about 25-30 percent.
It's lowered by at least 1.5 inches, and rides very nicely, using Monroe Sensatracs. Fieroguru showed a diagram of where to cut the bumpstops. Essentially, you just cut the wedge off of the top. Reduces the height of the bumper by about half.
Praise the Lowered!
[This message has been edited by Raydar (edited 04-27-2014).]
mrfiero
Total ratings: 150
Report this Post04-27-2014 10:28 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a set of Fiero Store lowered springs on my '88 GT about 20 years ago and also thought they were pretty harsh. I have no idea if the current ones they sell are the same as what I bought in the 90's, but I'm not willing to try again. Also, they seemed to settle....a lot. I loved the stance/look, but it felt like the springs were fully compressed all the time and you felt every single pebble/bump on the road.
Sourmug
Total ratings: 144
Report this Post04-27-2014 11:42 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a set on my front, but coil-overs on the rear. The front seems fine to me.
Nolan
Leeloo88
Report this Post04-28-2014 12:28 AM Click Here to See the Profile for Leeloo88Send a Private Message to Leeloo88Edit/Delete MessageReply w/QuoteDirect Link to This Post
When removed it definitely gives a more normal ride. Still stiff with the Konis but a lot more manageable. Still have to get the rear bumpstops off to get the full effect but taking it down the highway I could feel a marked improvement. Now I've got the problem identified I can cut them down a bit and re-install them so there's some protection from bottoming out. Though it would have to be a huge hit to compress this setup. Now to find a sanding belt and get them a little shorter.
"Fiero Fugit"
jscott1
Total ratings: 415
Report this Post04-28-2014 12:21 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have the Fiero store springs on my otherwise stock front 88 suspension and I dont find them too harsh. They are stiff but in a good way. I think the poly is too much for an 88 and probably contributes more to harshness than the springs.
Alex4mula
Report this Post04-28-2014 04:47 PM Click Here to See the Profile for Alex4mulaSend a Private Message to Alex4mulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nolan
Same here. Also on my other car I just replaced the front cut ones with them. Big difference for the good.
Red: TPI V8 + 6-Speed White: 3800SC auto
304rwHP/366rwTQ
tebailey
Report this Post04-28-2014 06:03 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just cut a coil off my fronts, and if you use a small cut off wheel you can get in and cut the top coil with the spring in. I don't recommend it, but my lower ball joint would not let go of the knuckle so I had no choice. Didn't want to loose a good ball joint. Few tips if you do go that route, unhook the shock and sway bar, that lets the front drop an extra inch to release a little more tension. Also go SLOW and don't get your hand anywhere near the spring when you get most of the way through. It will pop when it lets go. Then use a pry bar to pull the spring down just far enough to spin out the cut coil.
