  TurboTec's 85GT LS4 build thread (Page 2)
TurboTec's 85GT LS4 build thread by TurboTec
Started on: 04-12-2010 08:58 AM
Replies: 101 (4955 views)
Last post by: TurboTec on 10-12-2015 12:04 AM
darkhorizon
Total ratings: 451
Report this Post04-13-2010 09:21 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by TiredGXP:
Given the discussion about boost levels later in this thread, you'd probably be looking at a 300M input shaft, stronger chain and sprockets, and maybe a chrome moly output shaft...
I am fairly sure nobody has broken an output shaft... If anything a few pump shafts have broken, but never an output shaft?
when 80# injectors are CHEAPER than 60s now, why in the hell would you be going that small, then turn around and put a 110lb/m turbo on it?
I also challenge you to make sense of the reasoning behind running a turbo at HALF its flow rating, just to get 5% more "efficency" out of it.
dobey
Total ratings: 371
Report this Post04-13-2010 10:50 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Isolde:
Up to 15 psi, it's really not necessary. I can link you to several threads if you'd like to see what stock 5.3s can take. Including one car running high 9s in the 1/4 mile.
All the modern LSx engines can handle a bit of boost in stock build, sure. I wasn't suggesting it as a necessity, but asking what he was doing with it. I don't know what his plans are for racing or whatever with the vehicle. For 1/4 mile, it doesn't really much matter, since the 2-3 seconds at the high end of pressure isn't going to be enough to blow the heads off; for a few runs at least. Consistent trips down the track might weaken things up over time, though. But if your goal is pull a single 9s run in the 1/4 mile, then there are certainly more important things to worry about, and you won't need that much boost even, to get there with the LS4 in a Fiero.
TurboTec
Report this Post04-14-2010 07:44 AM Click Here to See the Profile for TurboTecClick Here to visit TurboTec's HomePageSend a Private Message to TurboTecEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well the injectors are easy, I have a set on the shelf in the garage that I'm not using for anything else.
I'm not looking for a challenge... But to me It's simple, just as people port their heads to gain that 5% or change headers for 5% or a better flowing intake for 5% It's all of the little things that make the hole better. Increasing efficiency is key to any project.
Sorry, I guess I don't understand your issue here... Turbos react to the amount of load applied to the turbine, 90% of of its life will not be at MAX boost unless it's in a pure racing application. It's happy putting out minimal boost until that 10% is required when a farting ricer comes up beside you asking for embarrassment...
Whatever turbo ends up in the car will be monitored and AR's adjusted for back pressure / boost ratio to achieve max efficiency at peak power...
I also plan on building one of these to help spool on larger turbos.
darkhorizon
Total ratings: 451
Report this Post04-14-2010 08:39 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
People port their heads for 30% gains, not 5%.. If you told someone that they wouldnt make any power under 4500 rpms, but they could make 5% more power past that, and it would cost them $1500 to do it, they would look at you very confused. I could put a giant cam on a motor, and it would be way more efficient, but it probably wouldnt be any faster than a properly sized cam, it would most likely be slower.
The saddest thing here is the fact that you can eliminate the inefficient boost, by simply putting a bigger intercooler on it. A true "have cake and eat it too" situation. This math might be a bit complex, but try to follow along.
A typical air/air intercooler can create a temp drop of about 75% over ambient, water to airs, could possibly do more than that. So lets assume a pretty typical blower outlet temperature of 200F and assume a temperature rise over ambient of 125F. Drop the intercooler in, and you end up with 110F engine temperature.
Now lets assume the same situation using a turbo that is 5% less efficient, because it is HALF the size of this T6 converted to T4 monster. Your blower outlet temp is now 230F, and you now have a 155F rise over ambient, and your crappy intercooler takes it down to a 118F inlet temperature.
Wow, the world is ending you now have a inlet temperature that is a whole 8 degrees higher than before! Lets go down to ebay, and get a $80 water to air intercooler that is conservatively 85% efficient (even though ice water could get it to nearly ambient, because the intercooler is properly sized for this airflow), and now you are MORE efficient than your giant turbo with a less than 100F inlet temperature.
Isolde
Total ratings: 133
Report this Post04-14-2010 08:41 AM Click Here to See the Profile for IsoldeSend a Private Message to IsoldeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dobey, that 9 second car isn't a one shot deal, the guy makes at least a half a dozen runs, EVERY weekend. That 5.3 gets beaten, hard. And yet it lives. The car is gutted, and is built for the dragstrrip. But the engine is stock except for a cam, pushrods, and valve springs. If you copied his combo into a Fiero, you'd be lucky to run mid 10s. High 9s are not the slam dunk you seem to think.
FieroWannaBe
Report this Post04-14-2010 08:53 AM Click Here to See the Profile for FieroWannaBeSend a Private Message to FieroWannaBeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Deleted.
[This message has been edited by FieroWannaBe (edited 04-14-2010).]
TurboTec
Report this Post04-14-2010 09:10 AM Click Here to See the Profile for TurboTecClick Here to visit TurboTec's HomePageSend a Private Message to TurboTecEdit/Delete MessageReply w/QuoteDirect Link to This Post
darkhorizon, why are you such a freek on this? I mean Damn...
I used your 5% number just to prove a point that every bit counts to the sum of a project no matter how insignificant you may think it is... Why do you care that I'm buying a larger compressor wheel than needed? Will it not work with a higher efficiency? I do understand how inter-coolers work as I have designed my fair share but thanks for the lesson anyway...
Again, thank you for your input...
Frank
TurboTec
Report this Post04-14-2010 12:41 PM Click Here to See the Profile for TurboTecClick Here to visit TurboTec's HomePageSend a Private Message to TurboTecEdit/Delete MessageReply w/QuoteDirect Link to This Post
TurboTec
Member since Feb 2010
Thanks, sorry to reply so late as I got distracted... Did you have any shops that you recommend?
dratts
Total ratings: 118
Report this Post04-14-2010 07:09 PM Click Here to See the Profile for drattsSend a Private Message to drattsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you saying that a 300M input shaft and chain are stronger and can be installed in a 4t65ehd?
dobey
Total ratings: 371
Report this Post04-14-2010 07:12 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
He always does this. You're just new. Just ignore and move on with the swap. I want to see the pics.
TiredGXP
Report this Post04-14-2010 08:10 PM Click Here to See the Profile for TiredGXPSend a Private Message to TiredGXPEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah - it's because it's a V8 thread.
[This message has been edited by TiredGXP (edited 04-14-2010).]
dobey
Total ratings: 371
Report this Post04-14-2010 08:14 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
30%? You're not going to get 30% porting your heads. At least not on an LS4. Maybe on a Briggs & Straton you will. Ported heads on a stock LS4 might net you 30hp, but that's 10%. On any head port job it's going to get you 5-10% hp increase. On an otherwise stock LS4, that's going to be between 15-30 hp. Porting the intake might gain a few more hp, but probably only 1-3% on the LS4 intake. So you're still about 55 hp short of getting that initial 30% out of the LS4. And yes, people pay large amounts of money for very little hp gain, all the time.
darkhorizon
Total ratings: 451
Report this Post04-15-2010 08:03 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
The heads comment was mostly referring to "old day" iron head type stuff. Heads coming out of GM in the last few years here have been pretty much ported out nicely from the factory. 30% gains are typical from 3800 head porting.
I didnt "troll" or "freak out" on this thread for reasons that should just be "ignored"... I just hate seeing good projects go down in flames because the goals were too extreme, and in this case it is too extreme for no reason. I also get a bit frustrated when "engineers" come into threads saying their "advanced engineering training" told them this was the best option, but they offer no explanation behind it.
For the "its a v8 thread" remark.. you missed the boat, severely.. Try reading the thread next time. I probably would have "freaked out" more if it was a 3800 thread honestly.
Isolde
Total ratings: 133
Report this Post04-15-2010 08:47 AM Click Here to See the Profile for IsoldeSend a Private Message to IsoldeEdit/Delete MessageReply w/QuoteDirect Link to This Post
In my years porting and flowing heads, very few designs get past 20% with basic clean up porting, and things like newer Hondas never even see 5% with a basic clean up job. they start out very very good. The heads that come on the LS4 are best left alone, especially if mild boost is to be added. Switching to the LS6 valves is extra beneficial for boost, as are better springs and pushrods. Even with a stock LS4 cam.The boost takes care of the flow, so keeping the original mixture motion will help more than porting.
darkhorizon
Total ratings: 451
Report this Post04-15-2010 09:31 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
LS6 valves will also help hold up to the extra heat as well.
I was not really suggesting that mild polish jobs are showing gains like 30%. I was referring to more of a CNC job.
This thread is not about heads, or porting them, we/I were/was just using the ballpark numbers to prove some points.
TurboTec
Report this Post04-15-2010 11:15 AM Click Here to See the Profile for TurboTecClick Here to visit TurboTec's HomePageSend a Private Message to TurboTecEdit/Delete MessageReply w/QuoteDirect Link to This Post
This thread is not about heads, or porting them...
Darkhorizon, you are correct about subject matter of this thread. I do appreciate you pointing that out...
______________________________________________________
Hey Isolde, I'm going with Ferrea stainless valves, Patriot hardened push rods and Patriot Gold springs (with the titanium retainer kit). I do have a set of CNC'd LS6 heads that I'm on the fence about using. I think it would really help as the low lift numbers were much higher which would increase my daily driving NA TQ/HP down low when not on boost...
My original plan was to get everything installed as stock, DYNO tune and have a little fun this summer with mild boost. Then make a winter project of making the tranny stronger, changing rod bolts, replacing heads ect... and turning it up a bit for next year...
Frank
[This message has been edited by TurboTec (edited 04-15-2010).]
Isolde
Total ratings: 133
Report this Post04-15-2010 01:16 PM Click Here to See the Profile for IsoldeSend a Private Message to IsoldeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, n/a I'd definitely do something in the way of better flow.
Rickady88GT
Total ratings: 200
Report this Post04-16-2010 12:20 AM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had plans to do an LS6 intake conversion along with a set of custom made headers. I like the turbo idea but I have no experience building a setup and buying one will be 4-5k?
dobey
Total ratings: 371
Report this Post04-16-2010 11:43 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will the LS6 intake fit on top of the DOD valley cover? Or are you going to delete the DOD also, and have to modify an LS2/3 valley cover to fit the intake? I'm going with an LS2 intake/valley cover on mine, but interested in seeing what you do for an LS6 intake, as it's slightly different, and I don't think anyone else has done it yet? At least, none of the Fiero swaps anyway. Maybe some of the GP/Impy guys did it?
Rickady88GT
Total ratings: 200
Report this Post04-16-2010 12:50 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am a member of a few forums and one of them is LS1tech. It covers the LS4. A few guys over there have swapped the LS6 intake. Most have deleted the DOD/AFM because of lackluster "performance" The DOD is only good for 2-4 mpg. BUT that depends on who you talk to and how they drive the car. In town I drive mine in third gear because the DOD only activates with the shifter in "D" and it kicks in at around 20mph and sounds crappy (I don't have a muffler) and just feels like it needs a tune up REALLY bad so I prevent it from turning on in town. On the freeway I use fourth gear and it activates but I hate it. It vibrates and is embarrassing when I give people a ride in it. I have polly mounts that are unforgiving and transmit the odd fire four banger vibrations straight into the seats. BUT from tank to tank calculated MPG is 25. That is better than I got with the stock 2.8.
I don't think I want to keep the DOD. This is a toy and I want it to be fun. Others have gone thru the trouble keeping the DOD with manifold swapps.
The stock LS4 manifold is VERRY restrictive. It is complete crap. Shame on GM for lack of performance engineering. Some claim that the LS6 swap is good for 30HP, I don't know but it is DEFINATLY going to bump up the power from the stock manifold. But maybe they handicapped the LS4 to save the tranny? Who knows.
[This message has been edited by Rickady88GT (edited 04-16-2010).]
Isolde
Total ratings: 133
Report this Post04-16-2010 12:58 PM Click Here to See the Profile for IsoldeSend a Private Message to IsoldeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey, I'm on LS1Tech also. I have no experience with running Ls4s, but I've driven a pickup with an AFM-equipped 6.0L, and I'm all in favor of deleting the AFM. It's too annoying. Can't GM refine it? The LS6 intake is about 10 hurses better than the LS2 intake, despite the difference in TB size. And for just 5.3L, you don't need a 90 mm TB, stock or boosted.
Rickady88GT
Total ratings: 200
Report this Post04-16-2010 01:45 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
That seems to be what most people say. The LS6 manifold is an upgrade even for an LS2.
TurboTec
Report this Post04-16-2010 02:02 PM Click Here to See the Profile for TurboTecClick Here to visit TurboTec's HomePageSend a Private Message to TurboTecEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Rick, this is why forums are so great, you get true "first hand experience", DOD delete for me... I also agree with you on the intake... I understand as to why, being GM took a cost saving approach to save money and use a DOD platform that covered other LSX motors but it's no excuse for this very poor design. On the other hand this same cost savings measure gives us the opportunity to retrofit with other platforms like the LS6 or LS2. Hell the LS1 intake is a huge improvement over the LS4... LOL
It's Funny GM developed one of the best flowing "stock out of the box" low cost cylinder heads ever produced the same year with the L92 / L76, go figure... If only the LS4 had a 4" bore!
Frank
[This message has been edited by TurboTec (edited 04-16-2010).]
dobey
Total ratings: 371
Report this Post04-16-2010 02:21 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
But the LS4 already has the same #243 heads that sit on top of the LS2 and LS6. The only differences are the valves and springs, and the fact that the LS4 isn't a 4" bore.
Isolde
Total ratings: 133
Report this Post04-16-2010 05:09 PM Click Here to See the Profile for IsoldeSend a Private Message to IsoldeEdit/Delete MessageReply w/QuoteDirect Link to This Post
LS6 isn't 4" bore, either. However, the LS4 can be bored to 3.898", and use LS6 pistons. Then you can build an LS6 into the LS4 block, have the packaging of the LS4, but the exact results of the LS6. This is good for anyone wanting to go with a manual trans, because the LS4 was never offered with a manual trans, but the LS6 only came with a manual trans.
The L92 / LS3 heads are interesting, except that the ratio of flow to port volume is the worst of any LSx head ever. But MAST has fixed this by releasing their own version, based on a whole new casting. These are so good they totally justify skipping the LS4 and tackling the LS3 block instead. And the LS3 block can be bored to 4.125". Combine with a 4.8 crank to get a high powered 5.7L that'll rev forever.
TurboTec
Report this Post04-16-2010 06:03 PM Click Here to See the Profile for TurboTecClick Here to visit TurboTec's HomePageSend a Private Message to TurboTecEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 4" bore comment was directed to the L92 heads with the 2.160" valve... I've got a set going on my 72 corvette build with an L76 intake. I'm going to use the 243's on the Fiero with an LS2 intake and FBW TB.
TurboTec
Report this Post04-16-2010 06:18 PM Click Here to See the Profile for TurboTecClick Here to visit TurboTec's HomePageSend a Private Message to TurboTecEdit/Delete MessageReply w/QuoteDirect Link to This Post
TurboTec
...the LS4 can be bored to 3.898", and use LS6 pistons....
I didn't know the sleeves could be bored that much, good to know... How much cylinder wall would that leave?
Isolde
Total ratings: 133
Report this Post04-16-2010 06:51 PM Click Here to See the Profile for IsoldeSend a Private Message to IsoldeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure, but GM says it's safe to 3.905", the O.D. of the cast-in iron sleeves are the exact same for LS1, LS6 and LS4 blocks. Again, that's according to GM themselves. I did it to my LS4 before I sold it. It looks fine, but the O.D. of the sleeves is larger at the very tops than it is from an inch down to the very bottom, which is all the same. Sorry if that's a confusing way of describing it.
TurboTec
Report this Post04-16-2010 08:01 PM Click Here to See the Profile for TurboTecClick Here to visit TurboTec's HomePageSend a Private Message to TurboTecEdit/Delete MessageReply w/QuoteDirect Link to This Post
...of the cast-in iron sleeves are the exact same for LS1, LS6 and LS4 blocks....
Very interesting... LS4 thick sleeves = great for boost!
dobey
Total ratings: 371
Report this Post04-18-2010 11:06 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
So any progress on your build?
TurboTec
Report this Post04-19-2010 07:22 AM Click Here to See the Profile for TurboTecClick Here to visit TurboTec's HomePageSend a Private Message to TurboTecEdit/Delete MessageReply w/QuoteDirect Link to This Post
No work on the Fiero this weekend, most of my time was spent on getting my driveway ready for concrete... Should all be finished this week, I hope...
I did get a Visit from Hardpact over the weekend, he brought his Blue fastback over for me to take a look at. Very nice car, Lambo doors are cool...
[This message has been edited by TurboTec (edited 04-19-2010).]
dobey
Total ratings: 371
Report this Post04-26-2010 12:22 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Inquiring minds want to know…
Any new news?
dobey
Total ratings: 371
Report this Post05-27-2010 03:19 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
So how is this swap going?
Dogcreek
Report this Post05-27-2010 10:45 PM Click Here to See the Profile for DogcreekSend a Private Message to DogcreekEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fill us in... I am very interested in how you are progressing! Watching the other LS4 builds is great information!!
Jeff
Tony Kania
Total ratings: 305
Report this Post05-27-2010 11:50 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
LS4! Have you people lost your friggin' minds? (Actually, good luck.)
[This message has been edited by Tony Kania (edited 05-27-2010).]
Hardpact
Report this Post05-28-2010 06:37 AM Click Here to See the Profile for HardpactSend a Private Message to HardpactEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey need any help droping that 2.8 out ....i'm your man !!!!!....will like to work off that drive train if i could....lol ~Tom
BLUE BY YOU!
NYFOC
darkhorizon
Total ratings: 451
Report this Post05-28-2010 08:59 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
"limited by funds"
dobey
Total ratings: 371
Report this Post05-28-2010 09:50 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heh. I haven't even started my thread yet. Need to get the engine first. But if you think the current LS4 swaps are crazy… just wait.
dobey
Total ratings: 371
Report this Post06-25-2010 08:22 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Still no progress?
TurboTec
Report this Post07-05-2010 09:54 PM Click Here to See the Profile for TurboTecClick Here to visit TurboTec's HomePageSend a Private Message to TurboTecEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry guys a lot going on with Family and work this spring, I've had no time... So sadly I haven't touched the project until today...
I removed the LS4 harness, all drive accessories, water pump and intake getting ready to remove the DOD valley cover, stock cam and lifters. I'm going with a LS3 non DOD valley pan, LS2 intake and a new cam which should work well with the 243 heads without loosing any snap down low but giving a nice bump up top.
Its GM's all purpose cam the same cam that's in the newer "F" bodies, 6.0L Vortec, 5.7L corvettes and GM's "327" 5.3L HO crate motor...
GM# 12561721
197/207 int/exh @ 0.05" duration
0.467" / 0.479" int/exh lift 116 LSA
I like the turbo friendly 116LSA. Tomorrow off to the dealer to buy valley pan gaskets and lifter trays and hopefully wrenching after work...
Tom give me a ring, lets do business... LOL
Frank
