  High Idle problem, help requested.
High Idle problem, help requested. by CoolBlue87GT
Started on: 01-09-2019 10:48 AM
Replies: 1 (1715 views)
Last post by: ZCR1 on 01-09-2019 07:12 PM
CoolBlue87GT
Total ratings: 151
Report this Post01-09-2019 10:48 AM Click Here to See the Profile for CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Moved to Technical Discussion & Questions
[This message has been edited by CoolBlue87GT (edited 01-20-2019).]
ZCR1
Report this Post01-09-2019 07:12 PM Click Here to See the Profile for ZCR1Send a Private Message to ZCR1Edit/Delete MessageReply w/QuoteDirect Link to This Post
You mean TPS Port or IAC port? If you suspect the EGR valve, you can always cut a piece of 22 gauge and place under the valve like a solid gasket. I've never messed with the IAC on these, but I know on other vehicles the motors are pretty easy to get out of adjustment, did you make sure it was in the fully closed position when you installed it?
[This message has been edited by ZCR1 (edited 01-09-2019).]
