I've got an 86 GT parts car that I need to get the engine out of. I've heard people say that the best way to remove an engine from a fiero is get the car up in the air and drop the whole subframe out from below. However, I don't have any way to get this car up in the air that high. So... I need to know what the best way is to get it out of the car from the top.
It's mated to an auto transmission. Should I pull them both at the same time? If I remove it without the transmission, are there any tricks to accomplishing it? I'm assuming there's a plate somewhere on the transmission that I can remove to get access to the flex-plate bolts?
Just looking for some advice from people who have done what I'm trying to do.
PS - I've already got all the visible wiring and hoses disconnected. I've also got the alternator (and bracket) removed, as well as all the strange little pipes (cold air ductwork?) and whatnot from the back of the engine compartment,plus the airbox. I plan to just cut the exhaust pipe with a sawzall.
Thanks in advance.
